This example uses the Solubility.jmp sample data table to extract two factors explained by six solvents. Select Help > Sample Data Library and open Solubility.jmp.
Select Analyze > Multivariate Methods > Factor Analysis.
Select 1-Octanol through Hexane and click Y, Columns.
Figure 7.2 Initial Factor Analysis Report
Factoring Method= Maximum Likelihood
Prior Communality= Common Factor Analysis
6.
Figure 7.3 Factor Analysis Report
The report lists the communality estimates, variance estimates, significance tests, measures of fit, rotated factor loadings, and a factor loading plot. The Rotated Factor Loadings and Factor Loading Plot suggest that Factor 1 relates to the Carbon Tetrachloride-Chloroform-Benzene-Hexane cluster of variables, and that Factor 2 relates to the Ether–1-Octanol cluster of variables. See Factor Analysis Model Fit Options for details of the information shown in the report.
Help created on 10/11/2018
