The design in the sample data table Extraction 3 Data.jmp is a definitive screening design for six factors in two blocks. The Add Blocks with Center Runs to Estimate Quadratic Effects option was selected and 4 Extra Runs were added in the design generation. The resulting design has 18 runs. This design is used to explore the analysis of a definitive screening design.
Help created on 10/11/2018
