JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Essential Graphing •
Treemaps
• Example of Treemaps
Example of Treemaps
To create treemaps, you can use either the Treemap platform or Graph Builder. This section provides examples for both.
To see the example using platforms, see
Example using the Treemap Platform
To see the example in Graph Builder, see
Example using Graph Builder
Help created on 10/11/2018
