Select Help > Sample Data Library and open Iris.jmp.
Select Graph > Scatterplot Matrix.
Select Sepal length, Sepal width, Petal length, and Petal width and click Y, Columns.
Select Species and click Group.
Figure 11.7 Initial Example Using a Grouping Variable
6.
From the red triangle menu, select Density Ellipses > Density Ellipses.
7.
From the red triangle menu, select Density Ellipses > Shaded Ellipses.
Figure 11.8 Example of a Scatterplot Matrix with Ellipses
Help created on 10/11/2018
