Produces chi-square test statistics and p-values for Wald tests of whether each parameter is zero.
Note: You can change the α level for the confidence intervals by selecting Set Alpha Level from the red triangle menu in the Fit Model launch window. The default α level is 0.05.
Creates a probability formula and saves it as a formula column script in the Formula Depot platform. If a Formula Depot report is not open, this option creates a Formula Depot report. See Formula Depot in the Predictive and Specialized Modeling book.
Creates a quantile formula and saves it as a formula column script in the Formula Depot platform. If a Formula Depot report is not open, this option creates a Formula Depot report. See Formula Depot in the Predictive and Specialized Modeling book.
Shows the interactive Effect Summary report that enables you to add or remove effects from the model. See Effect Summary Report in the Fitting Linear Models book.
