JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Design of Experiments Guide • Full Factorial Designs
A full factorial design defines an experiment where trials are run at all possible combinations of factor settings. A full factorial design allows the estimation of all possible interactions. Full factorial designs are large compared to screening designs, and since high-level interactions are often not active, they can be inefficient. They are typically used when you have a small number of factors and levels and want information about all possible interactions. For example, full factorial designs often form the basis for a measurement systems analysis (MSA).
Figure 11.1
Full Factorial Design for Three Two-Level Factors
Contents
Overview of Full Factorial Design
Example of a Full Factorial Design
Construct the Design
Analyze the Experimental Data
Full Factorial Design Window
Responses
Factors
Select Output Options
Make Table
Full Factorial Design Options
Help created on 10/11/2018
