Fun Fact: Linked Analyses
One of the powerful features in JMP is its linked analyses. The graphs and reports that you create are linked to each other through the data table. As shown in Figure 4.109, data that are selected in the data table are also selected in the three report windows. The linked analyses enable you to select data in one window and see where it occurs in the other windows. As you work through the examples in this chapter, keep the JMP windows open to see these interactions yourself.
Help created on 10/11/2018
