JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Using JMP •
Import Your Data
• Import Data from SAS
You can connect to a SAS server and work directly with SAS data sets.
Java Runtime Environment (JRE) Requirements
On Windows, Java Runtime Environment (JRE) 7 or later must be installed on your computer to access SAS. However, JRE 7 does not need to be specified as the current version.
On Macintosh, JRE 7 or later must be installed for SAS integration.
Note:
On Windows, the bitness of the JRE must match that of JMP. For example, 64-bit JMP communicates with both 32-bit and 64-bit SAS if the 64-bit JRE is installed. 32-bit JMP communicates with both 32-bit and 64-bit SAS if the 32-JRE is installed.
Help created on 10/11/2018
