JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Using JMP •
Import Your Data
• Import Data Using the Excel Add-In
The add-in for Excel provides new capabilities to JMP and Excel users on Windows:
Transfer selected cells in Excel to JMP data tables. See
Transfer Excel Data to a JMP Data Table
Use the JMP Profiler with calculation models in Excel workbooks. The profiler tool is designed to bring the power of the JMP profiler to models residing in Excel worksheets. You do not have to recreate your Excel models in JMP, verify that they are correct, and maintain the model in both JMP and Excel. For more information, see
Excel Profiler
in the
Profilers
book.
Note:
During the JMP installation, select the Excel Add-In. This installs the add-in for your version of Microsoft Excel.
Microsoft Excel 2010, Microsoft Excel 2013, and Microsoft 2016 are supported.
Help created on 10/11/2018
