The Control Panel for the Cytometry.jmp data table is shown in Figure 11.7. You can iteratively fit different numbers of clusters or you can specify a range using the Range of Clusters option.
Figure 11.7 Iterative Clustering Control Panel
Help created on 10/11/2018
