Launch the Formula Depot by selecting Analyze > Predictive Modeling > Formula Depot.
Figure 10.3 Empty Formula Depot from Launch
In platforms that do not publish prediction formulas to the Formula Depot, you can save the prediction formula to the data table. From the data table, add it to the Formula Depot by selecting Add Formula from Column. However, the scoring code might not be fully functional for such models. For details about scoring code see Generating Scoring Code from the Formula Depot Platform.
In addition, you can publish a formula directly from the formula editor. Select the formula, right-click, and select Publish expression to formula depot.
