The Output Options panel shown in Figure 2.23 is for the experiment in the Wine.jmp sample data table, located in the Design Experiment folder. In this example, you can choose various Run Order options and construct the design data table. Or, you can choose to go Back and restructure your design.
Figure 2.23 Output Options Panel for Wine Experiment
Help created on 10/11/2018
