Figure 1.14 JMP Home Window Actions
Tip: To prevent files that were opened by a script from appearing in the Recent Files window, select File > Preferences > General and de-select Add files opened by scripts to the Recent Files list.
To always automatically display the Window List inside maximized windows, select File > Preferences > Windows Specific and select Dock the Window List in maximized windows.
Tips:
To put the Home Window back into its original order, select View > Home Window Panes > Revert to Factory Layout.
If you close a panel and want to reopen it, select View > Home Window Panes and select the panel that you want to open.
Open the JMP Home Window by selecting View > Home Window or clicking the JMP Home Window button in the lower right corner of most JMP windows. If you cannot see the JMP Home Window button, select View > Status Bars.
Help created on 10/11/2018
