See Working with MATLAB in the Scripting Guide for details on working with MATLAB.
The following example sends the JMP variables x and y to MATLAB, executes the MATLAB statement z = x * y, and then gets the MATLAB variable z and returns it to JMP.
MATLAB Init();
x = [1 2 3];
y = [4 5 6];
MATLAB Execute( {x, y}, {z}, "z = x * y;" );
Show( z );
Suppose that a matrix named qbx and a structure named df are present in your MATLAB connection.
// Get the MATLAB variable qbx and placed it into a JMP variable qbx.
qbx = MATLAB Get( qbx );
// Get the MATLAB variable df and placed it into a JMP data table referenced by df.
df = MATLAB Get( df );
Table 1.1 shows what JMP data types can be exchanged with MATLAB using the MATLAB Get( ) function. Getting lists from MATLAB recursively examines each element of the list and sends each base MATLAB data type. Nested lists are supported.
Echo(Boolean) Sends MATLAB source lines to the JMP log. This option is global. The default value is true.
// Create a matrix, assign it to X, and send the matrix to MATLAB.
X = [1 2 3];
ml = MATLAB Send( X );
// Open a data table, assign a reference to it to dt, and send the data table along with its current row states to MATLAB.
ml = MATLAB Send( dt, Row States( 1 ) );
Table 1.2 shows what JMP data types can be exchanged with MATLAB using the MATLAB Send( ) function. Sending lists to MATLAB recursively examines each element of the list and sends each base JMP data type. Nested lists are supported.
Table 1.2 JMP and MATLAB Equivalent Data Types for MATLAB Send( )
MATLAB Init( );
X = 1;
MATLAB Send( X );
S = "Report Title";
MATLAB Send( S );
M = [1 2 3, 4 5 6, 7 8 9];
MATLAB Send( M );
MATLAB Submit( "
X
S
M
MATLAB Term( );
MATLAB Init();
mc = MATLAB Submit("/[
	x = rand(5);
	fprintf('%f/n', x);
	y = rand(5);
	fprintf('%f/n', x);
	z = plot(x, y);
Help created on 10/11/2018
