Figure 1.11 Noise Factor Example
Save the model to the data table with the Save > Prediction Formula command.
Launch the Profiler (from the Graph menu).
Assign the prediction formula to the Y, Prediction Formula role and the noise factors to the Noise Factor role.
Select Optimization and Desirability > Maximize Desirability from the Profiler menu.
Help created on 10/11/2018
