JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
JSL Syntax Reference •
JSL Messages
Display Boxes
• Nom Axis Boxes
Nom Axis Boxes
nom axis box<<Divider Lines(Boolean)
Adds or removes divider lines between labels in the axis box.
nom axis box<<Lower Frame(Boolean)
Adds or removes a lower frame around the axis.
nom axis box<<Rotated Tick Labels(Boolean)
Rotates or unrotates the labels at each tick value.
Help created on 10/11/2018
