JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
JSL Syntax Reference •
JSL Messages
Display Boxes
• Number Edit Box
Number Edit Box
number edit box<<Set Format(<width>, <decimal places>, <"Use thousands separator">)
Description
Sets the column format.
Arguments
A number of other formats can be set on number edit boxes. See
number col box<<Set Format(<width>|<width, decimal places>, <"Use thousands separator">)
for details about the syntax.
Numeric Formats
in the
Using JMP
book also describes the arguments.
Help created on 10/11/2018
