JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Using JMP •
Formula Editor
Customize Formulas
• Open and Close Arguments
When a formula is too large to fit on the screen, you can close formulas and arguments.
To close an argument, follow these steps:
Build a formula.
Highlight an argument or formula.
Right-click what you have highlighted.
Select
Close
or
Close Arguments
from the menu that appears.
Help created on 10/11/2018
