JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Reliability and Survival Methods •
Degradation
• Overview of the Degradation Platform
In reliability analyses, the primary objective is to model the failure times of the product under study. In many situations, these failures occur because the product degrades (weakens) over time. But, sometimes failures do not occur. In these situations, modeling the product degradation over time is helpful in making predictions about failure times. When an accelerating factor is included in the data, you can fit an accelerated degradation model.
The Degradation platform can model data that follows linear or nonlinear degradation paths. If a path is nonlinear, transformations are available to linearize the path. If linearization is not possible, you can specify a nonlinear model.
You can also use the Degradation platform to perform stability analysis. Three types of linear models are fit, and an expiration date is estimated. Stability analysis is used in setting pharmaceutical product expiration dates.
Help created on 10/11/2018
