(Option appears only if you right-click on the sheet.) Displays the Sheet Properties window. Available only if Sheet, points is selected in the Appearance Controls. For details, see Sheet or Surface Properties.
(Options appears only if you click on the surface.) Displays the Surface Properties window. Available only if Isosurface is selected in the Appearance Controls. For details, see Sheet or Surface Properties.
Opens a window for changing many plot settings. For more information about the OpenGL Scene commands, see Three-Dimensional Scenes in the Scripting Guide.
Figure 4.11 OpenGL View Settings
