Select Help > Sample Data Library and open Quality Control/Clips2.jmp.
Select Analyze > Quality and Process > Control Chart Builder.
Drag Date to the Subgroup zone.
Drag Gap to the Y zone.
Figure 10.21 XBar and R Control Chart for Gap
The control chart indicates that Gap is stable over time. Because Gap has the Spec Limits column property, a Process Capability Analysis report appears to the right of the control chart.
Figure 10.22 Histogram in Process Capability Analysis for Gap
The histogram and fitted normal blue curve suggest that the distribution of Gap is approximately normal. Although the process is stable, the distribution of Gap is shifted to the right of the specification range.
Right-click in the body of the Nonconformance report and select Expected Within PPM from the Columns submenu.
Figure 10.23 Capability Indices and Nonconformance Report
The estimates of out-of-specification product given in the Nonconformance report provide a direct measure of process performance. The PPM values in the Nonconformance report indicate that Gap hardly ever falls below the lower specification limit (1.4 parts per million). However, the number of parts for which Gap falls above the upper specification limit is 1869.0 parts per million.
Select Analyze > Quality and Process > Process Capability.
Select Gap and click Y, Process.
Open the Process Subgrouping outline.
Select Date in the Select Columns list and Gap in the Roles list.
Click Nest Subgroup ID Column.
6.
Figure 10.24 Goal Plot and Box Plot for Gap
Help created on 10/11/2018
