The Python interfaces are also scriptable using a Python connection object. A scriptable Python connection object can be obtained using the Python Connect() function. See Python Connect(<Echo(Boolean),> <Path(path),> <Use Python Version(string),> <Python System Path(list)>) in the JSL Syntax Reference.
Optional. Performs an Eval Insert() on the Python code before submission.
