An optional, Boolean, named argument. Performs an Eval Insert() on the R code before submitting to R.
x = [1 2 3];
y = [4 5 6];
rc = R Execute( {x, y}, {z}, "z <- x * y" );
// Get the R variable qbx and placed it into a JMP variable qbx
qbx = R Get( qbx );
// Get the R variable df and placed it into a JMP data table referenced by df
df = R Get( df );
	R Send(Here:x, R Name("localx"))
The named arguments for the Row States() argument are as follows:
X = [1 2 3];
rc = R Send( X );
Open a data table, assign a reference to it (dt), and send the data table, along with its current row states, to R:
rc = R Send( dt, Row States(1) );
An optional, Boolean, named argument. If set to true (1), the submit can be canceled either by pressing the ESCAPE key, or by using this message to an R connection: rconn<<Control( Interrupt( 1 ) ). False (0) is the default value.
rc = R Submit("\[
	x <- rnorm(5)
	print(x)
	y <- rnorm(5)
	print(y)
	z = plot(x, y)
Help created on 10/11/2018
