JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Fitting Linear Models •
Generalized Regression Models
Model Fit Reports
• Regression Plot
Regression Plot
Note:
The Regression Plot report appears only when there is one continuous predictor and no more than one categorical predictor. It is not available if the Distribution option is set to Multinomial, Ordinal Logistic, or Cox Proportional Hazards. The response must be continuous.
The Regression Plot report shows a plot of the response values on the vertical axis and the continuous predictor on the horizontal axis. A regression line is shown over the points. If there is a categorical predictor in the model, each level of the categorical predictor has a separate regression line and a legend appears next to the plot. If the response is specified as the counts of the number of successes and the number of trials, the number of successes divided by the number of trials is plotted on the vertical axis.
Help created on 10/11/2018
