JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Using JMP •
JMP Reports
Navigate Reports
• Resize a Window
Resize a Window
Report windows are automatically sized to fit the contents of the window. On Windows, you can automatically resize a window after manually resizing it. Hold down the Ctrl key and click the lower right corner of the window.
Help created on 10/11/2018
