JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Profilers •
Mixture Profiler
The Mixture Profiler Report
• Response Settings and Controls
Figure 5.6
Response
The list of one or more responses.
Contour
The current value of the contour on the mixture profiler. Click in the box to change the value. The slider control can also be used to change the value of the contour.
Current Y
The predicted response based on the current X settings. The value is at the center of the cross hairs on the profiler plot. This value updates as the factor settings are changed.
Lo Limit
Enables you to set a lower limit for your response.
High Limit
Enables you to set an upper limit for your response.
Note:
When response limits are used, the profiler shows regions that are feasible as unshaded.
Help created on 10/11/2018
