JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Fitting Linear Models •
Standard Least Squares Examples
• Response Surface Model Example
This example fits a response surface model. Your objective is to minimize the response.
Fit the Full Response Surface Model
Reduce the Model
Examine the Response Surface Report
Find the Critical Point Using the Prediction Profiler
View the Surface Using the Contour Profiler
Help created on 10/11/2018
