Run charts display a column of data as a connected series of points. The following example is a Run chart for the Weight variable from Coating.jmp in the Quality Control sample data folder (taken from the ASTM Manual on Presentation of Data and Control Chart Analysis).
Select Help > Sample Data Library and open Quality Control/Coating.jmp.
Select Analyze > Quality and Process > Control Chart > Run Chart.
Select Weight and click Process.
Select Sample and click Sample Label.
Figure 3.16 Run Chart
Help created on 10/11/2018
