Create a presentation by saving JMP results as a Microsoft PowerPoint presentation (.pptx). Rearrange JMP content and edit text in PowerPoint after saving as a .pptx file. Sections of a JMP report are exported into PowerPoint differently.
Note: On Windows, PowerPoint 2007 is the minimum version required to open .pptx files created in JMP. On Macintosh, at least PowerPoint 2011 is required.
(Windows) Select File > Save As and select PowerPoint Presentation from the Save as type list.
(Macintosh) Select File > Export > PowerPoint Presentation and click Next.
On Windows, EMF is the default format. On Macintosh, PDF is the default format.
The file opens in Microsoft PowerPoint because Open the file after saving is selected by default.
Help created on 10/11/2018
