Select Tables > Subset.
Select Subset by.
Select country from the Columns list and click OK.
Figure 9.17 New Subset Data Tables
6.
Select each new tab, select File > Save, and save the file on your computer.
7.
Select File > Save Project to save the data tables in the project.
Select File > New > Project to create an empty project.
Select File > Open, navigate to the JMP Samples/Data folder, and open Big Class Families.jmp.
(Windows) Select File > Save As and select PowerPoint Presentation from the Save as Type list.
Tip: Select Bookmark in project to add a bookmark to the file.
(Macintosh) Select File > Export (Macintosh) and select Microsoft PowerPoint .
Click Next, navigate to the desktop, and then click Export.
6.
In JMP, from the Bookmarks red triangle menu, select Add Files, navigate to the Graph Builder.pptx file that you created, and then click Open (Windows) or Choose (Macintosh).
Figure 9.18 Bookmarked PPTX File
Help created on 10/11/2018
