Click Add.
Open Polycity.jmp. You are interested in the relationship between POP, the population in thousands of the given city, and Ozone. Ozone is the response of interest, and POP is the continuous model effect.
Select Analyze > Fit Model.
Click Add.
Figure 1.4 Fit Model Window for Simple Linear Regression
When you click Run, the Fit Least Squares report appears, showing various results, including a Regression Plot. The Regression Plot shows the data and a simple linear regression model fit to the data (Figure 1.5).
Figure 1.5 Model Fit for Simple Linear Regression
Help created on 10/11/2018
