Select Help > Sample Data Library and open Companies.jmp.
Select Analyze > Distribution to open the Distribution launch window.
Select Profits ($M) in the Select Columns box and click the Y, Columns button.
The variable Profits ($M) appears in the Y, Columns role. See Figure 3.5 for the completed window.
Figure 3.5 Assign Profits ($M)
Figure 3.6 Distribution Report Window on Windows
On Windows, click the JMP Home Window button in the lower right corner to view the Home Window. On Macintosh, select Window > JMP Home.
Help created on 10/11/2018
