JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Scripting Guide •
Scripting Tools
Using the Script Editor
• Stop a Script
Stop a Script
To stop the script, press ESC on Windows (or COMMAND-PERIOD on Macintosh). You can also select
Edit > Stop Script
. On Macintosh,
Edit > Stop Script
is available only when the script is running.
Help created on 10/11/2018
