JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Basic Analysis •
Bivariate Analysis
Statistical Details for the Bivariate Platform
• Summary of Fit Report
RSquare
Using quantities from the corresponding analysis of variance table, the RSquare for any continuous response fit is calculated as follows:
RSquare Adj
The RSquare Adj is a ratio of mean squares instead of sums of squares and is calculated as follows:
The mean square for
Error
is in the Analysis of Variance report. See
Figure 4.35
. You can compute the mean square for
C. Total
as the
Sum of Squares
for
C. Total
divided by its respective degrees of freedom.
Help created on 10/11/2018
