Performs a varimax rotated partial singular value decomposition of the item transaction matrix to produce groups of items called topics. You can select this option multiple times to find different numbers of topics. See Topic Analysis.
Shows or hides a hierarchical clustering analysis of the items in the data. To the right of the dendrogram, there are options to set the number of clusters and save the clusters to a data table. For each item, this data table contains its frequency, the number of transactions that contain it, and its assigned cluster. For more information about clustering and dendrograms, see Dendrogram Report in Hierarchical Cluster.
