JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Design of Experiments Guide • Technical Details
Technical Details
This appendix contains information on the Alias Matrix, power calculations and the Relative Prediction Variance.
The Alias Matrix
Power Calculations
Contents
The Alias Matrix
Designs with Hard or Very Hard Factor Changes
Designs with If Possible Effects
Power Calculations
Power for a Single Parameter
Power for a Categorical Effect
Help created on 10/11/2018
