There are two types of t-Tests:
Equal variances. If you select the Means/Anova/Pooled t option, a Pooled t-Test report appears. This t-Test assumes equal variances.
Unequal variances. If you select the t-Test option from the red triangle menu, a t-Test report appears. This t-Test assumes unequal variances.
Shows the level of confidence (1-alpha). To change the level of confidence, select a new alpha level from the Set α Level command from the platform red triangle menu.
Value of the t-statistic.
The p-value associated with a two-tailed test.
The p-value associated with a upper-tailed test.
The p-value associated with an lower-tailed test.
