Select Macros > Response Surface.
Open the Odor Control Original.jmp sample data table. You want to fit a response surface to model the response, odor, as a function of temp and gl ratio. (Although you could include ht, as shown in the data table script Response Surface, for this illustration do not.)
Select Analyze > Fit Model.
Figure 1.20 Fit Model Window for Two-Factor Response Surface Model
Click Run.
Figure 1.21 shows a Surface Profiler plot of the data and a quadratic response surface fit to the data for the Odor Control Original.jmp sample data table. To obtain this plot, from the report’s red triangle menu, select Factor Profiling > Surface Profiler. To show the points, click the disclosure icon to open the Appearance panel and click Actual. If you want to make the points appear larger, right-click in the plot, select Settings and adjust the Marker Size.
Figure 1.21 Model Fit for a Degree-Two Polynomial in Two Variables
Help created on 10/11/2018
