JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Using JMP •
Formula Editor
Examples and Tutorials
• Use the Delete Expression Button
The following steps illustrate the results of repeatedly clicking the delete expression (or peel) button
Start with a formula.
Select a formula element.
Click the delete expression button
Click the delete expression again.
6.
7.
8.
9.
Help created on 10/11/2018
