Suppose that you want the values for a factor to appear in a different order in the Prediction Profiler. Consider an example of a wine tasting experiment, constructed using Custom Design. Wine is rated by five experts, each listed as a Rater in the Wine Data.jmp sample data table. Rater is a fixed blocking factor. Nine factors are studied. Rating is the response.
In the Table panel, click the green triangle next to the Reduced Model script.
Click Run.
Figure A.29 Profiler with Original Value Ordering
Notice that the values for De-Stem and Filtering appear in the order No followed by Yes. You want to reverse these, so that the Yes level appears first.
In the data table, click the asterisk next to De-Stem in the columns panel and select Value Ordering.
6.
Click Reverse.
7.
Click OK.
8.
9.
Click Reverse.
10.
Click OK.
11.
Again, click the green triangle next to the Reduced Model script.
12.
Click Run.
Figure A.30 Profiler with New Value Ordering
13.
Close the Wine Data.jmp sample data table without saving the changes.
