Create summary tables by using either the Summary or Tabulate commands. The Summary command creates a new data table. As with any data table, you can perform analyses and create graphs from the summary table. The Tabulate command creates a report window with a table of summary data. You can also create a table from the Tabulate report.
Select Help > Sample Data Library and open Companies.jmp.
Select Tables > Summary.
Select Type and Size Co and click Group.
Select Sales ($M) and Profits ($M) and click Statistics > Mean.
Figure 1.28 Completed Summary Window
JMP calculates the mean of Sales ($M) and the mean of Profit ($M) for each combination of Type and Size Co.
Figure 1.29 Summary Table
The N Rows column shows the number of rows from the original table that correspond to each combination of grouping variables. For example, the original data table contains 14 rows corresponding to small computer companies.
Select Analyze > Tabulate.
Figure 1.30 Tabulate Workspace
Select both Type and Size Co.
Drag and drop them into the Drop zone for rows.
Figure 1.31 Dragging Columns to the Row Zone
Right-click a heading and select Nest Grouping Columns.
Figure 1.32 Initial Tabulation
6.
Select both Sales ($M) and Profits ($M), and drag and drop them over the N in the table.
Figure 1.33 Adding Sales and Profit
The tabulation now shows the sum of Sales ($M) and the sum of Profits ($M) per group.
Figure 1.34 Tabulation of Sums
7.
The final step is to change the sums to means. Right-click Sum (either of them) and select Statistics > Mean.
Figure 1.35 Final Tabulation
Help created on 10/11/2018
