The following example uses the Coating.jmp data table. This quality characteristic of interest is the Weight 2 column. An XBar-chart and an S chart for the process are shown in Figure 3.19.
Select Analyze > Quality and Process > Control Chart > XBar.
Click OK.
Figure 3.19 XBar and S Charts for Varying Subgroup Sizes
Weight 2 has several missing values in the data, so you might notice the chart has uneven limits. Although, each sample has the same number of observations, samples 1, 3, 5, and 7 each have a missing value.
