Select Help > Sample Data Library and open Quality Control/Vial Fill Weights.jmp.
Select Analyze > Quality and Process > Control Chart Builder.
Drag Fill Weight to the Y role.
Drag Sample to the Subgroup role (at bottom).
Figure 3.26 XBar & R Chart for Fill Weight
Figure 3.27 3-Way Chart for Fill Weight
A Moving Range chart appears between the Range and Average charts. The limits on the Average (XBar) chart are now calculated using the moving range between each level of wafer in lot ID.
Help created on 3/19/2020
