Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
Formula Editor
• Add Operators
JMP.com/help
Add Operators
You can add operators to a formula using the keypad, which contains buttons that help build formulas. It includes common operators (also referred to as functions).
To build a formula using keypad operators at the top of the window, follow these steps:
Open the Formula Editor by right-clicking a column name in the data table and selecting
Formula
Select a box in the formula editing area by clicking it. (It is selected when there is a blue outline around it.) The operator performs its action on the area that is highlighted.
Select the column or variable that you want to use in your formula.
Click the keypad button(s).
Help created on 3/19/2020
