Select Analyze > Fit Model.
Select the following columns and click Add: Country, Weight, Turning Cycle, Displacement, and Horsepower.
Click Run.
Save the prediction formulas to columns by selecting Save Probability Formula from the Nominal Logistic red triangle menu.
Select Analyze > Predictive Modeling > Partition.
Select the Country, Weight, Turning Cycle, Displacement, and Horsepower columns and click X, Factor.
Make sure that Decision Tree is selected in the Method list.
Click OK.
6.
Click Split 10 times.
7.
Save the prediction formulas to columns by selecting Save Columns > Save Prediction Formula from the Partition red triangle menu.
Select Analyze > Predictive Modeling > Model Comparison.
Click OK.
Figure 10.8 Initial Model Comparison Report
Select ROC Curve from the Model Comparison red triangle menu.
Figure 10.9 ROC Curve for Medium
Select AUC Comparison from the Model Comparison red triangle menu.
Figure 10.10 AUC Comparison for Medium
