This example uses the SAT.jmp sample data table, which contains SAT test scores (divided into verbal and mathematics portions) for all 50 United States.
Select Help > Sample Data Library and open SAT.jmp.
Select Graph > Cell Plot.
Select State and click Label.
6.
7.
Right-click on the plot under 2004 Verbal (the top left cell) and select Sort Ascending.
Figure 10.6 Cell Plot for SAT Scores
From Figure 10.6, you notice the following:
Help created on 3/19/2020
