To use the animation feature, from the red triangle menu next to Data Filter, select Animation. Then select the variable that you want to animate. The highlighted frame around the variable indicates which variable is selected for animation.
The Animation Control panel (Figure 9.13) contains the following controls:
The square button (
Select Rows > Data Filter.
From the red triangle menu next to Data Filter, select Save Where Clause > To Script Window.
Select Where(
(:age == 12 | :age == 14) & :sex == "F" & (:height >= 56 & :height <= 60)
