Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
Save and Share Data
Create a Journal
• Append Reports to a Journal
JMP.com/help
To append other reports to a report that you already journaled, open the journal and select
Edit > Journal
. If an area of an analysis window is selected,
Edit > Journal
saves only the selected area instead of the entire window.
Notes:
The journal window has the same functions as the report window: you can click icons, click and drag, and right-click to access menus.
When a report is journaled, the journaled copy is no longer connected to the data table. To maintain that connection, save the report as JMP report and insert a link to it in the journal.
Help created on 3/19/2020
