Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Balanced Incomplete Block Designs
• Balanced Incomplete Block Design Window
JMP.com/help
The BIBD window updates as you work through the design steps. The outlines that appear, separated by buttons that update the outlines, follow the flow in
Figure 24.5
Figure 24.5
Balanced Incomplete Block Design Flow
The initial design window shows the Design Options outline.
Help created on 3/19/2020
