Select Graph > Graph Builder.
Drag the Latitude column to the Y axis.
Drag the Longitude column to the X axis.
Right-click the graph and select Graph > Background Map.
6.
On the Latitude axis, double-click 45°00’ N to open the Y Axis Settings window.
Right-click the graph and select Customize.
The boundaries that appear in the Background Map window are installed in the JMP Maps installation folder. See Custom Map Files for details about adding your own boundaries.
